LTC4217 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-09-01
5762
分享资料个
The LTC®4217 is an integrated solution for Hot Swap™
applications that allows a board to be safely inserted and
removed from a live backplane. The part integrates a Hot
Swap controller, power MOSFET and current sense resistor
in a single package for small form factor applications. A
dedicated 12V version (LTC4217-12) contains preset 12V
specifi c thresholds, while the standard LTC4217 allows
adjustable thresholds.
The LTC4217 provides separate inrush current control
and an accurate (5%) 2A current limit with current foldback
limiting. The current limit threshold can be adjusted
dynamically using an external pin. Additional features
include a current monitor output that amplifi es the sense
resistor voltage for ground referenced current sensing
and a MOSFET temperature monitor output. Thermal limit,
overvoltage, undervoltage and powergood monitoring are
also provided.
评论(0)
发评论
下载排行榜
