SN74LVC07A,pdf(Hex Buffer/Driv
消耗积分:3 | 格式:rar | 大小:737 | 2010-07-19
王越建
分享资料个
This hex buffer/driver is designed for 1.65-V to 5.5-V VCC operation.
The outputs of the SN74LVC07A device are open drain and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions. The maximum sink current is 24 mA.
Inputs can be driven from 1.8-V, 2.5-V, 3.3-V (LVTTL), or 5-V (CMOS) devices. This feature allows the use of this device as translators in a mixed-system environment.
评论(1)
发评论
jf_25101451 2024-10-01
0 回复 举报
太棒了,谢谢各位大神 收起回复
下载排行榜
全部1条评论
