SN74LVC126A-Q1,pdf9Quadruple B
消耗积分:3 | 格式:rar | 大小:151 | 2010-07-19
贾小龙
分享资料个
This quadruple bus buffer gate is designed for 1.65-V to 3.6-V VCC operation.
The SN74LVC126A features independent line drivers with 3-state outputs. Each output is disabled when the associated output-enable (OE) input is low.
To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver.
Inputs can be driven from either 3.3-V or 5-V devices. This feature allows the use of this device as a translator in a mixed 3.3-V/5-V system environment.
评论(0)
发评论
下载排行榜
