提高FLEX器件的系统速度—PLD设计技巧
消耗积分:3 | 格式:rar | 大小:666 | 2008-09-11
分享资料个
提高FLEX器件的系统速度—PLD设计技巧 Speed Example
I need the design run at 78MHZ
Design Requirement
􀂄The design need to run at 78Mhz or above
􀂄All the pin has been locked down, you can not changed any I/O pin
􀂄You are allowed to modify the circuit as far as the functional does not changed
􀂄You can use any design entry method
–Graphic
–AHDL
–VHDL
–anything you like
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
