MAX5875 pdf,MAX5875 datasheet
消耗积分:3 | 格式:rar | 大小:888 | 2008-09-11
分享资料个
The MAX5875 is an advanced 16-bit, 200Msps, dual
digital-to-analog converter (DAC). This DAC meets the
demanding performance requirements of signal synthesis
applications found in wireless base stations and other
communications applications. Operating from 3.3V and
1.8V supplies, this dual DAC offers exceptional dynamic
performance such as 78dBc spurious-free dynamic range
(SFDR) at fOUT = 16MHz and supports update rates of
200Msps, with a power dissipation of only 260mW.
The MAX5875 utilizes a current-steering architecture
that supports a 2mA to 20mA full-scale output current
range, and allows a 0.1VP-P to 1VP-P differential output
voltage swing. The device features an integrated 1.2V
bandgap reference and control amplifier to ensure
high-accuracy and low-noise performance. A separate
reference input (REFIO) allows for the use of an external
reference source for optimum flexibility and
improved gain accuracy.
The digital and clock inputs of the MAX5875 accept
3.3V CMOS voltage levels. The device features a flexible
input data bus that allows for dual-port input or a
single-interleaved data port. The MAX5875 is available
in a 68-pin QFN package with an exposed paddle (EP)
and is specified for the extended temperature range
(-40°C to +85°C).
Refer to the MAX5873 and MAX5874 data sheets for
pin-compatible 12-bit and 14-bit versions of the
MAX5875, respectively. Refer to the MAX5878 data
sheet for an LVDS-compatible version of the MAX5875.
Applications
Base Stations: Single/Multicarrier UMTS, CDMA, GSM
Communications: Fixed Broadband Wireless Access,
Point-to-Point Microwave
Direct Digital Synthesis (DDS)
Cable Modem Termination Systems (CMTS)
Automated Test Equipment (ATE)
Instrumentation
评论(0)
发评论
下载排行榜
