The MAX3453E–MAX3456E ±15kV ESD-protected USBcompliant transceivers interface low-voltage ASICs with USB devices. The devices fully comply with USB 1.1 and USB 2.0 when operating at full (12Mbps) and low (1.5Mbps) speeds. The MAX3453E–MAX3456E operate with VL as low as +1.65V, ensuring compatibility with low-voltage ASICs. The MAX3453E–MAX3456E feature a logic-selectable suspend mode that reduces current consumption to less than 40μA. Integrated ±15kV ESD protection protects the USB D+ and D- bidirectional bus connections. The MAX3453E supports only full-speed (12Mbps) operation. The MAX3453E/MAX3454E feature an internal 1.5kΩ USB pullup resistor and an enumeration function that allows devices to logically disconnect while plugged in. The MAX3453E/MAX3455E provide a pushpull bus-detect (BD) output that asserts high when VBUS > +4.0V. The MAX3453E–MAX3456E operate over the extended temperature range (-40°C to +85°C) and are available in 14-pin TSSOP and 16-pin (3mm x 3mm) thin QFN packages. Applications PDAs PC Peripherals Cellular Telephones Data Cradles MP3 Players
