SN74LVC2G157,pdf(Single 2-Line
消耗积分:3 | 格式:rar | 大小:515 | 2010-08-09
从未拥有
分享资料个
This single 2-line to 1-line data selector/multiplexer is designed for 1.65-V to 5.5-V VCC operation.
The SN74LVC2G157 features a common strobe (G) input. When the strobe is high, Y is low and Y is high. When the strobe is low, a single bit is selected from one of two sources and is routed to the outputs. The device provides true and complementary data.
NanoFree™ package technology is a major breakthrough in IC packaging concepts, using the die as the package.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
评论(0)
发评论
下载排行榜
