The DS3930 contains six 256-position nonvolatile (NV) potentiometers, 64 bytes of NV user EEPROM memory, and four programmable NV I/O pins. The six potentiometers all share a common low side. The potentiometers are separated into two groups of three 50kΩ potentiometers in parallel. Each group of three potentiometers shares a common high side and forms an equivalent resistance of 16.6kΩ (three 50kΩ potentiometers in parallel). Applications RF Transceivers Voltage References Power Supply Calibration Mobile Phones and PDAs Fiber Optic Transceiver Modules Portable Electronics Radio Tuners Small, Low-Cost Replacement for Mechanical Potentiometers
