SN74CB3T3245,pdf(8-BIT FET BUS
消耗积分:3 | 格式:rar | 大小:506 | 2010-08-16
王军
分享资料个
The SN74CB3T3245 is a high-speed TTL-compatible FET bus switch with low ON-state resistance (ron), allowing for minimal propagation delay. The device fully supports mixed-mode signal operation on all data I/O ports by providing voltage translation that tracks VCC. The SN74CB3T3245 supports systems using 5-V TTL, 3.3-V LVTTL, and 2.5-V CMOS switching standards, as well as user-defined switching levels (see Figure 1).
The SN74CB3T3245 is an 8-bit bus switch with a single ouput-enable (OE)\ input and a standard ’245 pinout. When OE\ is low, the 8-bit bus switch is ON, and the A port is connected to the B port, allowing bidirectional data flow between ports. When OE\ is high, the 8-bit bus switch is OFF, and a high-impedance state exists between the A and B ports.
评论(0)
发评论
下载排行榜
