SN74CBT3305C,pdf(DUAL FET BUS
消耗积分:3 | 格式:rar | 大小:392 | 2010-08-17
听风说梦
分享资料个
DESCRIPTION/ORDERING INFORMATION
The SN74CBT3305C is a high-speed TTL-compatible FET bus switch with low ON-state resistance (r on ), allowing
for minimal propagation delay. Active undershoot-protection circuitry on the A and B ports of the device provides
protection for undershoot up to – 2 V by sensing an undershoot event and ensuring that the switch remains in the
proper OFF state.
The SN74CBT3305C is organized as two 1-bit bus switches with separate output-enable (1OE, 2OE) inputs. It
can be used as two 1-bit bus switches or as one 2-bit bus switch. When OE is high, the associated 1-bit bus
switch is ON, and the A port is conncected to the B port, allowing bidirectional data flow between ports. When
OE is low, the associated 1-bit bus switch is OFF, and the high-impedance state exists between the A and B ports.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
