CY74FCT16500T,CY74FCT162500AT,
消耗积分:3 | 格式:rar | 大小:273 | 2010-08-21
分享资料个
These 18-bit universal bus transceivers can be operated in transparent, latched, or clock modes by combining D-type latches and D-type flip-flops. Data flow in each direction is controlled by output-enable (OEAB and OEBA\), latch enable (LEAB and LEBA), and clock inputs (CLKAB\ and CLKBA\) inputs. For A-to-B data flow, the device operates in transparent mode when LEAB is HIGH. When LEAB is LOW, the A data is latched if CLKAB\ is held at a HIGH or LOWlogic level. If LEAB is LOW, the A bus data is stored in the latch/flip-flop on the HIGH-to-LOWtransition of CLKAB\. OEAB performs the output enable function on the B port. Data flow from B-to-A is similar to that of A-to-B and is controlled by OEBA\, LEBA, and LKBA.
评论(0)
发评论
下载排行榜
