TPS22907,pdf(Ultra Small, Low
消耗积分:3 | 格式:rar | 大小:1940 | 2010-08-22
彭友旺
分享资料个
The TPS22907 is an ultra small, low RON load switch with controlled turn on. The device contains a P-channel MOSFET that operates over an input voltage range of 1.1 V to 3.6 V. The switch is controlled by an on/off input (ON), which is capable of interfacing directly with low-voltage control signals.
The TPS22907 is available in a space-saving 4-terminal WCSP with 0.5-mm pitch (YZT). The device is characterized for operation over the free-air temperature range of –40°C to 85°C.
评论(0)
发评论
下载排行榜
