TSB43CA43A/TSB43CB43A/TSB43CA4
消耗积分:5 | 格式:rar | 大小:157 | 2010-08-22
吴湛
分享资料个
The iceLynx-Micro (consumer electronics link with integrated microcontroller and physical layer (PHY)) is a high performance 1394 link-layer device designed as a total solution for digitally interfacing advanced audio/video consumer electronics applications. The device is offered in both a DTCP encryption/decryption version (TSB43CA43A and TSB43CA42) and a non-DTCP encryption/decryption version (TSB43CB43).
In addition to supporting transmit and receive of MPEG2 and DSS formatted transport streams with encryption and decryption, iceLynx-Micro supports the IEC 61883-6 and audio music protocol standards for audio format and packetizing, and asynchronous and asynchronous stream (as defined by 1394).
The device also features an embedded ARM7TDMI microprocessor core with access to 256K bytes of internal program memory.
评论(0)
发评论
下载排行榜
