TL145406,pdf(Triple RS-232 Dri
消耗积分:2 | 格式:rar | 大小:506 | 2010-09-01
打马过草原
分享资料个
The TL145406 is a bipolar device containing three independent drivers and receivers that are used to interface data terminal equipment (DTE) with data circuit-terminating equipment (DCE). The drivers and receivers of the TL145406 are similar to those of the SN75188 quadruple driver and SN75189A quadruple receiver, respectively. The pinout matches the flow-through design of the SN75C1406 to reduce the board space required and to allow easy interconnection. The bipolar circuits and processing of the TL145406 provide a rugged low-cost solution for this function at the expense of quiescent power and external passive components relative to the SN75C1406.
The TL145406 complies with the requirements of TIA/EIA-232-F and ITU (formerly CCITT) V.
评论(0)
发评论
下载排行榜
