OPA129,pdf(Ultra-Low Bias Curr
消耗积分:5 | 格式:rar | 大小:504 | 2010-09-14
张龙祥
分享资料个
The OPA129 is an ultra-low bias current monolithic operational amplifier offered in an 8-pin PDIP and SO-8 package. Using advanced geometry dielectrically-isolated FET (Difet®) inputs, this monolithic amplifier achieves a high performance level.
Difet fabrication eliminates isolation-junction leakage current—the main contributor to input bias current with conventional monolithic FETs. This reduces input bias current by a factor of 10 to 100. Very low input bias current can be achieved without resorting to small-geometry FETs or CMOS designs which can suffer from much larger offset voltage, voltage noise, drift, and poor power supply rejection.
The OPA129 special pinout eliminates leakage current that occurs with other op amps.
评论(0)
发评论
下载排行榜
