OP07C,OP07D,pdf(Low-Offset Vol
消耗积分:10 | 格式:rar | 大小:499 | 2010-09-17
王艳
分享资料个
These devices offer low offset and long-term stability by means of a low-noise, chopperless, bipolar-input-transistor amplifier circuit. For most applications, external components are not required for offset nulling and frequency compensation. The true differential input, with a wide input-voltage range and outstanding common-mode rejection, provides maximum flexibility and performance in high-noise environments and in noninverting applications. Low bias currents and extremely high input impedances are maintained over the entire temperature range. The OP07 is unsurpassed for low-noise, high-accuracy amplification of very-low-level signals.
These devices are characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
