TL343,PDF(SINGLE LOW-POWER OPE
消耗积分:2 | 格式:rar | 大小:209 | 2010-09-18
分享资料个
The TL343 is a single operational amplifier similar in performance to the µA741, but with several distinct advantages. It is designed to operate from a single supply over a range of voltages from 3 V to 30 V. Operation from split supplies also is possible, provided the difference between the two supplies is 3 V to 30 V. The common-mode input range includes the negative supply. Output range is from the negative supply to VCC – 1.5 V.
评论(0)
发评论
下载排行榜
