LTC6994参考设计及PCB布线规则
消耗积分:5 | 格式:rar | 大小:433 | 2010-09-22
路过秋天
分享资料个
Demonstration circuit 1562A is an engineering tool
to design and evaluate the LTC699X-X family of
TimerBlox circuits. The center section of the board
contains a pre-configured TimerBlox function.
DC1562A comes in twelve timing function variations
as outlined in Table 1.
Surrounding the center board is a ”playground”
prototyping area. The prototyping area has pads
for Dip-8, S8, MS8, or S6 packages with bread
boarding connections to each pin and two convenient
power buses and ground bus surrounding the
entire area. This area is for conditioning signals to
control the timer function and for adding loads controlled in time.
评论(1)
发评论
小小的奢求 2013-08-15
0 回复 举报
全是英文,而且是PDF 收起回复
下载排行榜
全部1条评论
