DRV8813,pdf(Dual-Bridge Motor
消耗积分:5 | 格式:rar | 大小:318 | 2010-09-26
哈哈哈
分享资料个
The DRV8813 provides an integrated motor driver solution for printers, scanners, and other automated
equipment applications. The device has two H-bridge drivers, and can drive a bipolar stepper motor or two DC
motors. The output driver block for each consists of N-channel power MOSFET’s configured as full H-bridges to
drive the motor windings. The DRV8813 can supply up to 2.5-A peak or 1.75-A RMS output current (with proper
heatsinking at 24 V and 25°C).
A simple parallel digital control interface is compatible with industry-standard devices. Decay mode is
programmable.
Internal shutdown functions are provided for over current protection, short circuit protection, under voltage
lockout and overtemperature.
TheDRV8813 is available in a 28-pin HTSSOP package with PowerPAD™ (Eco-friendly: RoHS & no Sb/Br).
评论(0)
发评论
下载排行榜
