UC2950,pdf(Half-Bridge Bipolar
消耗积分:3 | 格式:rar | 大小:221 | 2010-09-28
张艳
分享资料个
This device is a monolithic integrated circuit designed to provide high-current switching with low saturation voltages when activated by low-level logic signals. Source and sink switches may be independently activated without regard to timing as a built-in interlock will keep the sink off if the source is on.
This driver has the high current capability to drive large capacitive loads with fast rise and fall times; but with high-speed internal flyback diodes, it is also ideal for inductive loads. Two UC2950s can be used together to form a full bridge, bipolar motor driver compatible with high frequency chopper current control.
评论(0)
发评论
下载排行榜
