The AL3158 is a low noise, constant frequency charge pump DC/DC converter that uses a Dual mode load switch (1x), and (2x) conversion for white LED applications. The AL3158 is capable of driving three groups of three LED channels at 20mA from a 2.7V to 5.5V input. The current sinks may be operated using three simple PWM dimming inputs individually or in parallel for driving highercurrent LEDs. Low external part counts (one 1μF flying capacitor and two 2.2μF capacitors at VIN and VOUT) make this part ideally suited for small, battery-powered applications. AL3158 PWM dimming inputs are used to enable, disable device and dimming LED current with a fixed default current settings at 20mA or other factory programming options available. Each output of the AL3158 is equipped with built-in protection for VOUT short circuit and auto-disable for LED short conditions. Built-in soft-start circuitry prevents excessive inrush current during start-up and mode switching. A low-current shutdown feature disconnects the load from VIN to reduce quiescent current less than 1μA. The AL3158 is available in a lead-free, space-saving, thermally enhanced 20-pin 3 x 3mm QFN package.
