MAX6023 pdf datasheet (UCSP Vo
消耗积分:3 | 格式:rar | 大小:666 | 2008-10-01
李霞
分享资料个
The MAX6023 is a family of low-dropout, micropower
voltage references in a 5-bump, chip-scale package
(UCSP™). The MAX6023 series-mode (three-terminal)
references, which operate with input voltages from 2.5V
to 12.6V (1.25V and 2.048V options) or (VOUT + 0.2V) to
12.6V (all other voltage options), are available with output
voltage options of 1.25V, 2.048V, 2.5V, 3.0V,
4.096V, 4.5V, and 5.0V. These devices are guaranteed
an initial accuracy of ±0.2% and 30ppm/°C temperature
drift over the -40°C to +85°C extended temperature
range.
UCSPs offer the benefit of moving to smaller footprint
and lower profile devices, significantly smaller than even
SC70 or SOT23 plastic surface-mount packages. The
significantly lower profile (compared to plastic SMD
packages) of the UCSP makes the device ideal for
height-critical applications. Miniature UCSP packages
also enable device placement close to sources and
allow more flexibility in a complex or large design layout.
The MAX6023 voltage references use only 27μA of supply
current. And unlike shunt-mode (two-terminal) references,
the supply current of the MAX6023 family varies
only 0.8μA/V with supply-voltage changes, translating to
longer battery life. Additionally, these internally compensated
devices do not require an external compensation
capacitor and are stable up to 2.2nF of load capacitance.
The low-dropout voltage and the low supply current
make these devices ideal for battery-operated
systems.
Applications
Hand-Held Equipment
Data Acquisition Systems
Industrial and Process Control Systems
Battery-Operated Equipment
Hard-Disk Drives
评论(0)
发评论
下载排行榜
