基于MAX7033的ASK超外差式接收电路设计
消耗积分:10 | 格式:rar | 大小:798 | 2010-12-06
分享资料个
 所设计的315 MHz/433 MHz ASK超外差式接收机电路采用MAX7033高集成度、低功耗CMOS、超外差式幅移键控(ASK)接收机,接收频率范围为300 MHz~450 MHz,射频信号输入范围为-114 dBm~0 dBm,数据速率可达33 kb/s曼彻斯特码率(66 kb/s NRZ)。介绍了MAX7033的主要技术性能、内部结构、工作原理和应用电路。
Abstract:
 The 315MHz/433MHz ASK superheterodyne receiver adopts high integrated,low power COMS,superheterodyne,ASK receiver MAX7033. It has a receiving frequency range of 300 MHz to 450 MHz,the input RF signal range of -114 dBm to 0 dBm,and a data rates of 33kbps manchester data speed.The main performance,interior structure,working principle and application circuit of MAX7033 are introduced in detail.?
评论(1)
发评论
111040699 2013-03-22
0 回复 举报
好!!! 收起回复
下载排行榜
全部1条评论
