基于C#运用遗传算法的排课系统
消耗积分:10 | 格式:rar | 大小:751 | 2010-12-10
刘杰
分享资料个
 排课问题是典型的组合优化和不确定性调度问题,并且是NP完全问题。随着高校的发展,在教务管理系统中使用的排课模型也变得越来越复杂,针对遗传算法排课中存在的初始解生成不合理及一周多学时课程不好安排的问题,为了避免同一门课程在一周内的不合理上课情况。针对这种情况,给出了排课问题的数学模型,提出了基于C#运用遗传算法解决方案。结果表明,该算法能比较有效的解决排课问题。该方法易于学习和应用,且不必依赖特殊的实现模式。
Abstract:
 The problem of timetabling system is the typical of combinatorial optimization and uncertainty, and it also is NP-completeness problem. With the development of colleges and universities,the class arrangement model is also becoming more and more complicated in the educational administration system. In view of this situation, the paper presented the mathematical model of the problem, and proposed solutions to apply genetic algorithm based on C sharp. The results show that the algorithm can solve the timetabling problem effectively. This method is easy to learn and apply. And it does not need any special realization model.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
