OP955 pdf datasheet (PIN Sili
消耗积分:2 | 格式:rar | 大小:666 | 2008-10-08
王丽
分享资料个
The OP955 devices consists of a PIN
silicon photodiode molded in a clear
epoxy package which allows spectral
response from visible to infrared
wavelengths. The wide receiving angle
provides relatively even reception over a
large area. The side-looking package is
designed for easy PC board mounting.
The lensing effect of the package allows
an acceptance half angle of 45o
measured from the optical axis to the half
power point. These devices are 100%
production tested using infrared light for
close correlation with Optek’s GaAs and
GaAlAs emitters.
评论(0)
发评论
下载排行榜
