电力电缆故障测量中接地电流消除方法
消耗积分:3 | 格式:rar | 大小:3956 | 2010-12-13
建立建利12
分享资料个
 在倒置电桥法测量电力电缆故障的基础上,提出了一种消除接地电流的新方法。在应用倒置电桥法测量之前,接入一套由电阻和直流电源组成的接地电流消除电路,通过调节可调电阻器消除其接地电流。分析了该方法的基本电路原理,给出了推导过程,并通过模拟实验验证了该测量方法的有效性。
Abstract:
 This paper presents a new measure to eliminate the ground current for fault location of power cable and analyses the basic principle of inversion bridge method.Before using the inversion bridge method for fault location, switch-on a circuit combined with resistances and direct-current source, the ground current can be completely eliminated by adjusting the resistance value.The paper analyses the eliminating measure circuit principle, sets out the deducing process, and sets up a model experiment to test the validity of the measure.
评论(0)
发评论
下载排行榜
