介绍一种雷达视频信号模拟器的电源设计,采用三片高效同步电压转换器TPS54310为DSP、FPGA等器件提供内核电压和外围I/O电压,并通过电压监控器件TPS3307-18D实时监控由TPS54310产生的电压,从而实现DSP、FPGA的内核电压与外围I/O电压的顺序上电及复位。
- Abstract:
- A kind of power design for the radar video signal simulator are introduced in the paper.In the design, three high efficiency and synchronous-buck PWM switchers TPS54310 are adopted to supply core voltage and I/O voltage for DSP and FPGA.And the voltage monitor TPS3307-18D is utilized to monitor the voltage generated by TPS54310,which ensures both the reset circuit and the power-on sequence of the core voltage for DSP and FPGA and the peripheral I/O voltage.
