基于AT89C52单片机的温度巡回检测系统设计
消耗积分:10 | 格式:rar | 大小:896 | 2010-12-20
李杰
分享资料个
阐述了一个由上位PC机和AT89C52下位单片机组成的主从分布式温度巡回检测系统。主从机采用RS-485 串行通讯标准进行通信,可在下位单片机实现基本的温度数据巡回检测基础上,由上位PC机实现综合处理功能或扩展为远程操作。整个系统具有巡检速度快,扩展性好的特点。
Abstract:
 In this paper,a top PC and AT89C52 under-bit microcontrollers from the main component of the tour distributed temperature detection system is presented. Master and slave can use RS-485 serial communication standards for communications.Based on next-bit machine for basic goods temperature detected data Tour, the top can achieve the integrated treatment of PC functions or for the expansion of long-distance operation. The entire inspection system is fast, expansion.
评论(2)
发评论
2011-06-27
0 回复 举报
正需要呢,谢谢分享~~ 收起回复
sheshenyouling 2011-05-11
0 回复 举报
kuangding   嘿嘿 收起回复
下载排行榜
全部2条评论
