application up to 400 mA, with a super high flux output and
presented in a compact package outline. (6.0 x 6.0 x 1.5).
With its low package height of 1.5 mm it presents the best
combination of compactness and highest brightness.
The following application note details product specification
in corresponding data sheets for the different series of the
product.
The InGaN based devices are casted with silicone. Silicone
casting has big advantages in terms of optical stability and
stress relief, but requires a special handling procedure in
assembly.
For the solder process there is no special requirement. The
device is compatible to the existing SMT processes and
standard IR-reflow.
