介绍了以TMS320F28334为主体,以HL402B驱动器为功率驱动电路,交流电动机为控制对象的伺服系统模块设计方案。给出电流检测、电流保护、PWM波生成以及功率驱动模块的实现。该系统模块具有体积小、功耗低、集成度高等特点,对同类系统的开发和研究具有一定的参考价值。
- Abstract:
- The design of a servo system module is introduced,which uses TMS320F28334as main body,HL402B as power-driven circuit,and AC motor as the control object.The current detect circuit,current protect circuit,PWM wave and power-driven module are given.The servo system features smaller volume,lower power and higher integration.It is a good example for development similar system.
