基于VHDL的微型打印机控制器设计
消耗积分:10 | 格式:rar | 大小:423 | 2010-12-23
王丽
分享资料个
介绍基于VHDL的微型打印机控制器的设计。论述了微型打印机的基本原理,以及实现控制器的VHDL语言设计。打印机的数据来自系统中的存储模块,根据需要控制打印。该微型打印机控制器可取代传统的微型打印机,且抗干扰性好,可靠性高,具有较强的移植性,稍加改动就可应用于不同场合。
Abstract:
 This paper introduced the design method of micro printer controller based on VHDL.The basic principles of microprinter is explained,as well as the realization of the controller by VHDL language.The printer data is from the system memory modules,can control printer.The design of microprinter controller has antigood and high reliability,it can replace the traditional printer.The controller has very good portability,and need little modify that can use in different situation.
评论(0)
发评论
下载排行榜
