FPGA的全局动态可重配置技术
消耗积分:10 | 格式:rar | 大小:623 | 2011-01-04
张静
分享资料个
FPGA的全局动态可重配置技术主要是指对运行中的FPGA器件的全部逻辑资源实现在系统的功能变换,从而实现硬件的时分复用。提出了一种基于System ACE的全局动态可重配置设计方法,首先介绍Xilinx System ACE技术,详细分析FPGA的全局动态可重配置的原理,使用System ACE控制器件和Compact Flash卡,并讨论了其中的若干细节,然后基于System ACE实现了Virtex-5系列FPGA全局动态可重配置。实验结果表明,该方法稳定可靠,可实现8种不同比特流的动态配置,与传统的
Abstract:
 Technology of Field Programmable Gate Array(FPGA)global dynamic reconfiguration is mainly used to reconfig-ure its total logical sources at run time,and changes its functions on system,in order to achieve the hardware time-division multiplexing.A method of FPGA global dynamic reconfiguration based on system ACE was presented.Xilinx System ACE technology was introduced firstly,FPGA dynamically reconfigurable principle and some details were discussed in detail,the System ACE controller and Compact Flash card were used in this design as the significant segment,and then Virtex-5series FPGA global dynamic reconfiguration based on system ACE was implemented.The results of application indicate that the method is steady and reliable,and can implement global dynamic reconfiguration between eight bit files,and more flexible compared with the traditional configuration.
评论(0)
发评论
下载排行榜
