单片机P0口的片外数据存储器扩展
消耗积分:10 | 格式:rar | 大小:706 | 2011-01-04
王磊
分享资料个
单片机作为一种微型计算机,其内部具有一定的存储单元(8031除外),但由于其内部存储单元及端口有限,很多情况下难以满足实际需求。为此介绍一种新的扩展方法,将数据线与地址线合并使用,通过软件控制的方法实现数据线与地址线功能的分时转换,数据线不仅用于传送数据信号,还可作为地址线、控制线,用于传送地址信号和控制信号,从而实现单片机与存储器件的有效连接。以单片机片外256KB数据存储空间的扩展为例,通过该扩展方法,仅用10个I/O端口便可实现,与传统的扩展方法相比,可节约8个I/O端口。
Abstract:
 As a micro-computer,the SCM internal memory has a certain units(except8031),but because of its internal storage units and the ports are limited,in many cases it can not meet the actual demand.So we introduced a new extension method,the data line and address lines combined through software-controlled approach to realize the time-conversion functions of data lines and address lines,so the data lines not only transmited data signals,but also served as address lines and control lines to transmit address signals and control signals,in order to achieve an effective connection of microcontroller and memory chips.Take microcontroller chip with256KB of data storage space expansion as example,through this extension method,with only10I/O ports it was achieved,compared with the traditional extension methods,this method saves8I/O ports.
评论(0)
发评论
下载排行榜
