FTE6000 可调激光光源光纤测试光源TLS
型号: FTE6000
--- 产品参数 ---
公司logo
上海屹持光电技术有限公司
221內容 |  9w浏览量  |  25粉丝
--- 产品详情 ---
The Terahertz Technologies FTE-6000 C Band Hand Held Tunable Laser Source (TLS) is manufactured
in a rugged splash proof housing with a highly protective boot. Our TLS displays in wavelength, frequency or ITU channel. The Tunable Laser Source is a great match with our FTE-8000 (Optical Spectrum Analyzer) for installation, commissioning and trouble shooting of DWDM networks. The FTE-6000 offers a fast start up with minimal warm up required and provides very stable wavelength and power outputs. As with all of our advanced tests equipment series, the FTE-6000 is affordable, easy to use and rugged. Ask about our kit offerings, such as the FTE-8600 Combo Kit.
Features
► Selectable Step Size Down to 50 GHz
► Selectable Start & Stop Channels
► Settable in Wavelength or Frequency
► Settable Dwell Time
► Rugged Case with Impact Resistant Boot
► USB PC Interface with Remote operation Capability
► Battery Operated or International Line Voltage
► Simple Operation with On-Line Help Mode
► Lowest Cost Hand Held Tunable Laser Source
► Interchangeable Fiber Optic Connectors
► Up to 88 Channels on the ITU Grid
► Fast Turn-On
Ordering Information
FTE-6000CC-Band Tunable Laser Source
FTE-SCASE-LG Soft Case for FTE-7500, FTE-6000 and FTE-8000 Series
FTE-6000 Specifications
Frequency RangeFTE-6000 C 192 - 196 THz (1529-1563nm)
Accuracy1.5 GHz
Line Width 1 MHz
Side Mode Suppression Ration45 dB
Output Power>12 dBm
Attenuation Range0 - 5 dB
Power Setting Resolution0.01 dB
Power Variation over
Wavelength Range
± 0.5 dB
Minimum Channel Spacing50 GHz (0.4nm)
Fiber Type9/125 μm (Non-PM)
Relative Intensity Noise-140 dB/Hz
Graphical Display4 in Color TFT
Power Supply / ChargerUniversal 100-240V witn Interchangeable Mains
BatteryBattery Rechargeable NiMH -  4hr
Storage Temperature-20 to 60 C
Operating Temperature Range-10 to +40 C
Dimensions (w/out rubber boot )7.75” L x 4.5” W x 2.25” H     (197mm L x 114mm W x 57mm H)
Weight 2 lbs
Connector StylesFC  SC Interchangeable
Accessories ProvidedUniversal Power Adapter w/US, UK, Continental Europe, and Australian Plugs, Interchangeable FC/ST and SC Adapters, Certsoft VI Software, Rubber Boot and Manual on CD
上海屹持光电技术有限公司
