LED驱动器集成MOSFET,电路保护,以减少设计复杂度。
消耗积分:0 | 格式:rar | 大小:0.17 MB | 2017-06-23
分享资料个
  工程师面临的最大挑战之一是如何在不牺牲性能或功能的前提下简化设计。对于LED照明,设计师们会很好地评估他们的LED驱动器选项非常密切。这些驱动程序集成了多个组件,包括MOSFET和电路保护装置,以及其他功能,使设计更简单。
  在所有组件集成的情况下,总是有权衡,但哪些设计师可以忍受的是由每个单独的应用程序决定的。LED驱动集成的两个最大问题是缺乏灵活性和散热问题。
  在这篇文章中,我们将看一个AC / DC和DC / DC LED驱动器的样品,承诺减轻设计的复杂性,节省空间,加快上市时间。例如,许多LED驱动白炽灯泡替代应用集成1或4 MOSFET,这不仅简化设计和减少设计时间,还节省电路板空间和成本削减物料清单(BOM)通过无需外部元件。这些部分也满足了系统电路保护的要求结合过热保护,欠压锁定,热关断等保护功能,提高了系统的可靠性。最后,这些驱动程序通过缩短设计和合格周期来加快产品的发布速度。
  “When everything is integrated, it‘s very good for the mass market because it’s very easy to design with and [the part] offers a very small form factor,” said Jim Patterson, systems and applications manager, Lighting Power Products, Texas Instruments, Inc. “That combination makes time to market much quicker, because issues like EMI performance have already been well tested in the package.”
  Patterson also admits “retrofit lamps are a difficult market due to the size constraints,” adding that “you‘re taking a light bulb, such as a MR16 or GU10, in very small two-inch-diameter envelopes that have to fit all the electronics.”
评论(0)
发评论
下载排行榜
