HB发光二极管的驱动程序使设计者能够构建卤素灯和白炽灯的替代品
消耗积分:0 | 格式:rar | 大小:0.20 MB | 2017-08-05
分享资料个
  卤素灯和白炽灯虽然很受欢迎,但在当今充满电力意识的绿色世界中,存在着一些关键问题。灯消耗了大量的电力,通常在几千小时的使用后烧坏。
  Figure 1: Typical HBLED replacement for popular halogen and incandescent lamps
  LED retrofit lamp solutions
  Halogen and incandescent lamps, although popular, present some key concerns in today’s power conscious, green world. The lamps consume a lot of power and typically burn out after a few thousand hours of use. The latest high-brightness LEDs (HBLEDs) offer a great alternative — they use a lot less power and can last about ten times as long. However, designing HBLED replacements for popular halogen and incandescent lamps such as the MR16, PAR20, A19 (Figure 1), and others present three key design challenges:
  The retrofit lamp must fit in the same socket as the lamp it replaces, which means it should have the same form factor.
  The retrofit must not only manage the high amount of power dissipated by the LEDs by having proper heat sinking but operate at high temperature while maintaining high reliability and a long lifetime.
  Finally, retrofits must be electrically compatible with the existing lighting infrastructure (wiring, dimmers, etc.).
评论(0)
发评论
下载排行榜
