emc1184是高精度低成本、I2C/SMBus四通道温度传感器
消耗积分:0 | 格式:rar | 大小:0.42 MB | 2017-09-28
分享资料个
  The EMC1184 is a high accuracy, low cost, I2C/SMBus four channel temperature sensor. Advanced features such as Resistance Error Correction (REC), Beta Compensation (to support CPU diodes requiring the BJT/transistor model) and automatic diode type detection combine to provide a robust solution for complex environmental monitoring applications.
  The EMC1184 monitors four temperature channels (three external and one internal)。 It provides ±1°C accuracy for both external and internal diode temperatures. Frequency hopping and analog filtering ensure remote diode traces can be as far as 8 inches without degrading the signal.
评论(0)
发评论
下载排行榜
