The EMC1184 is a high accuracy, low cost, I2C/SMBus four channel temperature sensor. Advanced features such as Resistance Error Correction (REC), Beta Compensation (to support CPU diodes requiring the BJT/transistor model) and automatic diode type detection combine to provide a robust solution for complex environmental monitoring applications.
The EMC1184 monitors four temperature channels (three external and one internal)。 It provides ±1°C accuracy for both external and internal diode temperatures. Frequency hopping and analog filtering ensure remote diode traces can be as far as 8 inches without degrading the signal.
