基于TQM879008下的1.5-2.7 GHz ½ W Digital Variable Gain Amplifier
消耗积分:0 | 格式:pdf | 大小:0.77 MB | 2018-07-25
分享资料个
  Applications 
  3G / 4G Wireless Infrastructure 
  CDMA, WCDMA, LTE  Repeaters 
  ISM Infrastructure
  Product Features 
  1.5-2.7 GHz Frequency Range 
  41.1 dB Maximum Gain at 2.5 GHz 
  31.5 dB Gain Range in 0.5 dB Steps 
  +47.5 dBm Output IP3 
  +27.3 dBm Output P1dB 
  Fully Internally Matched Module 
  Integrated Blocking Capacitors, Bias Inductors
   3-wire SPI Control Programming
  General Description
  The TQM879008 is a digital variable gain amplifier (DVGA) featuring high linearity over the entire gain control range. This amplifier module integrates two gain blocks, a digital-step attenuator (DSA), and a high linearity ½ W amplifier. The module has the added feature of integrating all matching components, bias chokes and blocking capacitors. The internal 6-bit DSA provides a 31.5 dB gain control range in 0.5 dB steps, and is controlled with a serial periphery interface (SPITM)。
  The TQM879008 features variable gain from 10 dB to 41.1dB at 2.5 GHz, +47.5 dBm output IP3, and +27.3 dBm P1dB. The module operates from a single +5V supply and is available in a compact 28-pin 6x6 mm leadless SMT package.
  The TQM879008 is pin compatible with the TQM829007 (0.7-1.0GHz, 0.25W DVGA) and TQM879006 (1.4- 2.7GHz, 0.25W DVGA)。 This allows one to size the right type of device for specific system level requirements as well as making the DVGA family ideal for applications where a common PCB layout is used for different frequency bands.
评论(0)
发评论
下载排行榜
