FAN5362,pdf (3MHz, 500mA Synch
消耗积分:0 | 格式:rar | 大小:433 | 2010-09-30
分享资料个
The FAN5362 is a 500mA, step-down, switching voltage
regulator that delivers a fixed output voltage from an input
voltage supply of 2.7V to 5.5V. Using a proprietary
architecture with synchronous rectification, the FAN5362 is
capable of delivering a peak efficiency of 96%, while
maintaining efficiency over 90% with load currents as low
as 1mA.
This regulator transitions seamlessly into and out of 100%
duty cycle operation when the supply dips to or below the
regulation setpoint and smoothly recovers full regulation
without overshoot when the supply recovers.
The regulator operates at a nominal fixed frequency of
3MHz, which reduces the value of the external components
to 1μH for the output inductor and 4.7μF for the output
capacitor. The PWM modulator can be synchronized to an
external frequency source.
At moderate and light loads, pulse frequency modulation is
used to operate the device in power-save mode with a
typical quiescent current of 45μA. Even with such a low
quiescent current, the part exhibits excellent transient
response during large load swings. At higher loads, the
system automatically switches to fixed-frequency control,
operating at 3MHz. In shutdown mode, the supply current
drops below 1μA, reducing power consumption. For
applications that require minimum ripple or fixed frequency,
PFM mode can be disabled using the MODE pin.
The FAN5362 is available in 6-bump, 0.4mm pitch, Wafer-
Level Chip-Scale Package (WLCSP).
评论(0)
发评论
下载排行榜
