SA614A pdf datasheet(Low power
消耗积分:3 | 格式:rar | 大小:176 | 2008-10-18
鼠爱米
分享资料个
The SA614A is an improved monolithic low-power FM IF system incorporating two limiting intermediate frequency amplifiers, quadrature detector, muting, logarithmic received signal strength indicator, and voltage regulator. The SA614A features higher IF bandwidth (25MHz) and temperature compensated RSSI and limiters permitting higher performance application
评论(0)
发评论
下载排行榜
