TP3155 pdf datasheet (Time Slo
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-21
淡淡的爱
分享资料个
TP3155 Time Slot Assignment Circuit
General Description
The TP3155 is a monolithic CMOS logic circuit designed to
generate transmit and receive frame synchronization pulses
for up to 8 COMBOTM CODEC/Filters. Each frame sync
pulse may be independently assigned to a time slot in a
frame of up to 32 time slots. Assignments are controlled by
loading in an 8-bit word via a simple serial interface port.
This control interface is compatible with that used on the
TP3020/TP3021 and 2910/2911 CODECs, enabling an
easy upgrade to COMBO CODEC/Filters to be made.
Features
Y Controls up to 8 COMBO CODEC/Filters
Y Independent transmit and receive time slot assignments
Y 8-channel unidirectional mode
Y Up to 32 time slots per frame
Y Serial control interface compatible with TP3020/TP3021
CODECs
Y LS TTL and CMOS compatible inputs
Y 5 mW, 5V operation
评论(0)
发评论
下载排行榜
