MSC1162/MSC1162A pdf datasheet
消耗积分:2 | 格式:rar | 大小:555 | 2008-10-28
郝埃连
分享资料个
The MSC1162A is a monolithic IC designed for directly driving the grid and anode of the vacuum fluorescent display tube. The device contains a 40-bit bidirectional shift register, a 40-bit latch circuit, and 40-output circuit on a single chip. Display data is serially stored in the shift register at the rising edge of a clock pulse. Setting the *CL pin low allows all the driver outputs to be driven low, which makes it possible to set the display blanking. Also, setting both of the *CL and CHG pins high allows all the driver outputs to be driven high, which provides the easy testing of all lights after final assembly of a VFD tube panel. The MSC1162A is compatible with the MSC1162.
评论(0)
发评论
下载排行榜
