ML2253/ML2254/ML2256 pdf datas
消耗积分:5 | 格式:rar | 大小:555 | 2008-10-28
訾存贵
分享资料个
The ML2250 family is a 2-channel mixing speech synthesis device with an on-chip voice data (i.e., phrases)
storing mask ROM and a flash memory. Besides playing the built-in voice data, this device can output voice data
that is input from outside the device. This ML2250 family allows selecting the playback method from the 8-bit
PCM, non-linear 8-bit PCM, 16-bit PCM, 2-bit ADPCM2, and 4-bit ADPCM2 algorithms. And the sound volume
is adjustable as well.
The ML2250 family incorporates a 14-bit D/A converter and low-pass filter.
It is easy to configure a speech synthesizer by externally connecting a power amplifier and a CPU to the ML2250
family.
The ML2250 family line-up includes 2 types of products: with on-chip mask ROM, and with on-chip flash
memory.
ML2251/52/53/54/56-XXX
This is a CMOS single chip speech synthesis device with an on-chip mask ROM. Products with 5 types of mask
ROMs are available in the ML2250 family depending upon the total playback time length.
ML22Q54/Q58
The ML22Q54/Q58 is a speech synthesis device with a 4-Mbit/8-Mbit flash memory built in. The voice data can
be easily written to the flash memory using a special tool. The on-chip flash memory product is suitable for the
diversified low volume production or short delivery time applications that the on-chip mask ROM product
cannot support. The ML22Q54/Q58 is most suitable for evaluation because the circuit configuration is the same
as the on-chip mask ROM product.
评论(0)
发评论
下载排行榜
