DS1862A pdf datasheet (XFP Las
消耗积分:3 | 格式:rar | 大小:555 | 2008-11-15
麻酱
分享资料个
The DS1862A is a closed-loop laser-driver control IC
with built-in digital diagnostics designed for XFP MSA.
The laser control function incorporates automatic power
control (APC) and allows extinction ratio control though
a temperature-indexed lookup table (LUT). The
DS1862A monitors up to seven analog inputs, including
temperature and monitor diode (MD) current, which are
used to regulate the laser bias current and extinction
ratio. Warning and alarm thresholds can be programmed
to generate an interrupt if monitored signals
exceed tolerance. Calibration is also provided internally
using independent gain and offset scaling registers for
each of the monitored analog signals. Settings such as
programmed calibration data are stored in passwordprotected
EEPROM memory. Programming is accomplished
through an I2C-compatible interface, which can
also be used to access diagnostic functionality.
Applications
Laser Control and Monitoring 10Gbps Optical
Transceiver Modules (XFP)
Digital Diagnostics in Optical Transmission
评论(0)
发评论
下载排行榜
