74HC390/74HCT390 pdf datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-01
分享资料个
The 74HC/HCT390 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC
standard no. 7A. The 74HC/HCT390 are dual 4-bit decade ripple counters divided into four separately clocked sections. The counters have two divide-by-2 sections and two divide-by-5
sections. These sections are normally used in a BCD decade or bi-quinary configuration, since they share a common master reset input (nMR). If the two master reset inputs (1MR and 2MR) are used to simultaneously clear all 8 bits of the counter, a number of counting configurations
are possible within one package. The separate clocks (nCP0 and nCP1 ) of each section allow ripple counter or frequency division applications of divide-by-2, 4, 5, 10, 20,25, 50 or 100. Each section is triggered by the HIGH-to-LOW transition of the clock inputs (nCP0 and nCP1 ). For BCD decade operation, the nQ0 output is connected to the nCP1 input of, the divide-by-5 section. For bi-quinary decade operation, the nQ3 output is connected to the nCP0 input
and nQ0 becomes the decade output.The master reset inputs (1MR and 2MR) are active HIGH
asynchronous inputs to each decade counter which operates on the portion of the counter identified by the “1”and “2” prefixes in the pin configuration. A HIGH level on the nMR input overrides the clocks and sets the four outputs LOW.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
