OPA622 pdf datasheet (1Wide-Ba
消耗积分:2 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The OPA622 is a monolithic amplifier component
designed for precision wide-bandwidth systems
including high-resolution video, RF and IF circuitry,
and communications equipment. It includes a monolithic
integrated current-feedback operational
amplifier block and a voltage buffer block, which,
when combined, form a voltage-feedback operational
amplifier.
When combined as a current-feedback amplifier, it
provides a 280MHz large-signal bandwidth at ±2.5V
output level and a 1700V/ms slew rate. The output
buffer stage can deliver ±70mA output current. The
high output current capability allows the OPA622 to
drive two 50W or 75W lines with ±3V output swing,
making it ideal along with the low differential
gain/phase errors for RF, IF, and video applications.
评论(0)
发评论
下载排行榜
