CA3262A, CA3262 pdf datasheet(
消耗积分:2 | 格式:rar | 大小:78 | 2008-12-22
贾大林
分享资料个
Features
• Independent Over-Current Limiting On Each Output
• Independent Over-Temperature Limiting On Each Output
• Output Drivers Capable of Switching 700mA Load
• Inputs Compatible With TTL or 5V CMOS Logic
• Suitable For Resistive, Lamp or Inductive Loads
• Power-Frame Package Construction For Good Heat
Dissipation
• Operating Temperature Ranges
- CA3262A . . . . . . . . . . . . . . . . . . . . . . . -40oC to 125oC
- CA3262 . . . . . . . . . . . . . . . . . . . . . . . . . -40oC to 85oC
Applications System Applications
• Solenoids • Automotive
• Relays • Appliances
• Lamps • Industrial Controls
• Steppers • Robotics
• Small Motors
• Displays
评论(0)
发评论
下载排行榜
