Features • MOSFET Input Stage - Very High ZI; 1.5TΩ (1.5 x 1012Ω) (Typ) - Very Low II; at 15V Operation. . . . . . . . . . . . . 5pA (Typ) at 5V Operation. . . . . . . . . . . . . 2pA (Typ) • Common-Mode Input Voltage Range Includes Negative Supply Rail; Input Terminals Can be Swung 0.5V Below Negative Supply Rail • CMOS Output Stage Permits Signal Swing to Either (or Both) Supply Rails • CA5160 Has Full Military Temperature Range Guaranteed Specifications for V+ = 5V • CA5160 is Guaranteed to Operate Down to 4.5V for AOL • CA5160 is Guaranteed Up to ±7.5V
