HA-2556 pdf datasheet(57MHz, W
消耗积分:2 | 格式:rar | 大小:603 | 2008-12-28
王杰
分享资料个
The HA-2556 is a monolithic, high speed, four quadrant,
analog multiplier constructed in the Intersil Dielectrically
Isolated High Frequency Process. The voltage output
simplifies many designs by eliminating the current-to-voltage
conversion stage required for current output multipliers. The
HA-2556 provides a 450V/μs slew rate and maintains
52MHz and 57MHz bandwidths for the X and Y channels
respectively, making it an ideal part for use in video systems.
评论(0)
发评论
下载排行榜
